Perform this procedure to configure LLDP-MED network policies on specific ports.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Select Port MED.
  3. Select the Local Policy tab.
  4. Select Insert.
  5. In PortNum, select the ellipsis (...).
  6. In Port Editor: PortMembers dialog box, select the desired ports.
  7. Select OK.
  8. In PolicyAppType, select the application type.
  9. Optional: In PolicyVlanId, type the VLAN ID for the port.
  10. Optional: In PolicyPriority, type the priority level.
  11. Optional: In PolicyDscp, type DSCP value.
  12. Optional: Select Policy Tagged to enable VLAN tagging on the port.
  13. Select Insert.
Local Policy Field Descriptions
Use the data in the following table to use the Local Policy tab.
Name
Description
PortNum
Specifies the port.
PolicyAppType
Specifies the application type.
PolicyVlanId
Specifies the VLAN ID for the port, as defined in IEEE 802.1Q-2003. The value 0 is used if the device is using priority tagged frames, which means only the 802.1D priority level is significant, and the default VLAN ID of the ingress port is used instead.
PolicyPriority
Specifies the Layer 2 priority used for the specified application type, as defined in IEEE 802.1D-2004. The default is 0.
PolicyDscp
Specifies the value of the Differentiated Service Code Point (DSCP) associated with a specific port on the local LLDP-MED, as defined in IETF RFC 2474 and RFC 2475. The default is 0.
PolicyTagged
Specifies whether the application uses a tagged or untagged VLAN, as defined by IEEE 802.1Q-2003.
  • true — uses tagged VLAN
  • false — uses untagged VLAN or does not support a port-based VLAN
